DXF import / surface forming issues
zak_morrow
zak_morrow Member Posts: 2
Hi, all!
I'm having an issue when importing a DXF into sketchs. After importing, I tried going through the whole sketch and making relevant points/lines coincident throughout, but after reviewing it for a long while and still not getting a closed surface I'm hoping one of you might be able to help:
https://cad.onshape.com/documents/d0922bc48473672d2afc50ff
Source DXF is at
http://www.budind.com/dxf/hbext9165.dxf
Is there a trick to forming a closed surface?
  • sam_18
    sam_18 Member Posts: 1
    I'm having an identical issue with another DXF; does anyone else have input on this?
