Problem with liner pattern of feauture
OpenR2
OS Professional Posts: 188 ✭✭✭
So if I take a sketch and extrude a fixed distance I can linerar pattern the resulting feature with expected results.
If I take a sketch and extrude up to a plane....when I try to create the linear patter...it tries to keep the plane used in the definition fixed instead of offsetting it.
Is this intended? I think this might be a bug.
I'm not sure which plane is fixed in this picture or how it might offset. could you elaborate?0
Very clever Narayan, and easy to grasp with your screen caps!0
OK...that is a little different....but let me try that....it looks like that will work.0
