How do I make a square hole in a part?
andrew_carter
Member Posts: 1 ✭
Hi, I just started using onshape and I cannot find any tutorial or guide on how to make a square hole. I've had no problem with regular circular holes, but I cannot figure out how to make different shapes of holes!
Thanks
Thanks
create a sketch on the surface or plane where you want your hole to start, dimension the square and then use the extrude icon, make sure the subtract selection is highlighted then set your depth, hit the green check symbol. Hope that helps.1
2
