Login error: None of provided URLs available
It seems I can work on my parts and assemblies but I cannot create a drawing of any type. When I try I receive the following error message
I have tried logging off and logging back into the system but I still receive the same error message. Does anyone have any suggestions?
@joseph_la_rocque,Generally it is not happening. Can you please open a support ticket and give some more details to Onshape support team they definitely help you.If you would like help with a document or you have encountered a bug, you opt to Share the document with Onshape support by clicking the Share with Onshape support toggle button at the bottom left of the dialog. When shared, the toggle button turns blue.
When a document is shared with Onshape support, the Share toggle button turns blue; at any time you can unshare the document with Onshape support by clicking the toggle link again.
5
5 -
@joseph_la_rocque we are seeing this as well. This is not a problem on your end. We are looking into this now.
John Rousseau / VP, Technical Operations / Onshape Inc.0 -
I must of not been holding my mouth right. It's working now.0
We have resolved this issue. I apologize for the lost productivity. This was a lingering failure from the problems we had earlier today.
We have resolved this issue. I apologize for the lost productivity. This was a lingering failure from the problems we had earlier today. All systems in all regions are healthy now.
