Why can't I get a dimension between these two points?
I'm trying to measure the distance between the centers of two circles and it says "Dimensions must be between two different geometries." What can I do to get the measurement I need?
paul_chastell Onshape Employees Posts: 126
Note that in the latest version of Onshape you can measure geometry by clicking on it: the measurement appears at the bottom right of the window. Your workaround using dimensions should no longer be necessary.Paul Chastell
TVP, Onshape R&D5
This discussion has been closed.
TVP, Onshape R&D
Note: if one of the points is not only outside the sketch but off the sketch plane then the dimension will show the distance to the position of the point when projected onto the plane, not the 3d distance.
TVP, Onshape R&D
TVP, Onshape R&D
