Private document limit
JWP
Member Posts: 11 PRO
I have over time created 9 private documents.
I have now deleted 7 of them and only have 2
The counter still says 9 of 10, tried logging Off and back On.....Still 9 of 10.
Is there something else I need to do?
HI Jon. Documents in your trash count towards your limit. You can empty your trash to get rid of them.
Please open a support ticket if you still aren't seeing the right counts and we will take a closer look.John Rousseau / VP, Technical Operations / Onshape Inc.5
Hi Jon. We have recalculated your document counts. Sorry for the hassle. We are working on fixing the problems with tracking these counts.John Rousseau / VP, Technical Operations / Onshape Inc.0
Hi John, Thanks but its still not correct, there are 5 documents I've started, 3 of which are private, 2 shared. Count is at 5 of 10 private
Please open a support ticket if you still aren't seeing the right counts and we will take a closer look.John Rousseau / VP, Technical Operations / Onshape Inc.5 -
I have the same problem. I deleted all my documents, emptied the trash and my account document count is 6 of 10, not 00
Hi Ken. Sorry for the hassle. Your counts have been recomputed. A better fix for this is in the works.John Rousseau / VP, Technical Operations / Onshape Inc.0
