Not all extrusions included in part
patrick_joy
Member Posts: 2 ✭
Hi,
I created a part in the part assembly by drawing a sketch and then adding three extrusions.
But when I add this part in the assembly tab only one of the extrusions is included and not the total part.
I'm sure it is my lack of understanding of the software but I can't seem to figure out why all the extrusions aren't being included.
Any ideas?
Thanks
Any ideas?
Thanks
You extruded several of your lines as simple surfaces and not as part of a body / part. Assemblies only consist of parts. Check those two latter Extrusions and make sure they either Add or Merge.5
@patrick_joy, surfaces are not yet supported in assemblies. Perform a thicken on the surface to get a part will definitely work for you.
5
5 -
Thank you both, this makes sense now.
