Inserting Image show up as a black rectangle
tom_percy
tom_percy Member Posts: 1 ✭✭
Hi, I have inserted images before but it seems when i try to import a PNG (6mb) it doesn't work. It just comes up as a blank black rectangle. I have tried converting the PNG to a JPG (30mb) (via photoshop) but had the same problem.
Any help would be appreciated.
Cheers, Tom
  • c_a_moore
    c_a_moore Member Posts: 6 ✭✭
    I've seen a number of strange things during import of graphics objects, most surrounding what seems to be a relative scaling between part studio and the graphic.  Do you see anything if you zoom in closely on graphic?
    Another consideration is possibly using a raw format such as TIFF.  Compression-based formats (esp. JPG) are difficult at times.  In my experience it is usually helpful to keep trying different formats until something works, as well as trying different conversion methods/tools.
    Finally, we detected a bug a few months ago (haven't checked to see if fixed) where graphics objects imported into a part studio would disappear when a drawing was generated from part.
    Good luck!
