Offset tool on Text?
matthew_mucker
Member Posts: 7 ✭✭
Is it possible to use the offset tool on text in a sketch?
I'm designing a thingamabob to print on my 3D printer. I want to print and object, then have a text inlay printed as a separate part that snaps into the first part. I'm new at 3D printing, but I'm comfortably certain that I need to allow a small gap between the text inlay and the hole for the text inlay. So I was thinking that I'd create a text object in the sketch, then use the offset tool to create the gap, extrude both, use the boolean function to cut the text-plus-offset out of the first part, then remove the offset extrusion and have my text part remain.
But I can't get the offset tool to work with a text object in a sketch. Am I missing something here, or am I just out of luck?
matthew_mucker , Currently user cannot use Offset for sketch text in Onshape. You can raise improvement request for this. In near future we hope that this facility will be provided by Onshape.
Can you offset the individual letters?
HWM-Water Ltd0 -
@owen_sparks, Currently it is not possible for user to offset even individual letter also.
What you can do, however, is first extrude the text, and then boolean-subtract it with an offset (and the "keep tools" option checked).Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc2
Good thinking Ilya, thanks.
Owen S
HWM-Water Ltd0 -
is This still true in 2024?2
Dissapointing that this feature has not been added almost 8 years later.
Would be a good ticket item for an intern.2 -
It seems to have been solved by @Ilya_baran two posts above?
Engineering textbook: https://hwh.stephenteacher.com/txtbook.html1 -
New to OnShape, coming from Shapr3d. Could someone demonstrate or explain the steps to achieve the above "solution"?
Here is a quick example with clearance around each letter.
