DXF Export Resolution
I have a sketch made of splines, but when I export it as a dxf, the resolution in the spline segments isn't very good. So rather than having a smooth curve I end up with lots of rough segments. Is there a way to increase the resolution of the export or fix this issue? Thanks.
  • Narayan_K
    Narayan_K Member Posts: 379 ✭✭✭
    @ hunter_francoeur,Have tried this "Refine graphics" option.
    The geometry in drawings views is displayed in Onshape as short lines. For performance purposes, Onshape uses the minimum number of short lines so that curves look smooth at your current zoom. At times, when you zoom in, the short lines may look coarse.
    Use the Refine Graphics tool to recompute the lines, resulting in geometric curves looking smoother. The underlying geometry in your views remains unchanged.
  • ellen_timiney
    ellen_timiney Member Posts: 10 ✭
    I can only find "refine graphics" in the drawing tab. Export to DWG/DXF from a sketch, or from faces will always make visible straight lines. I have to process these further in my CAM package to re curve them.
