How do I create a hole when Start from Sketch Plane not visible
patrick_callahan
Posts: 1 ✭
I'm creating a hole in a part, and following the help for "Hole"
The Start from sketch plane option is not visible in the Hole popup, and I can't select a point for where to put the hole.
5. Indicate Start from sketch plane to start the hole from the sketch plane (this may change where the counterbore/countersink, clearance and tapped portions of the screw are located)
What am I missing other than experience using CAD tools?
-Pat
-Pat
@patrick_callahan, just like you need a sketch to create an extrude, you also need to create a sketch with your hole locations as points before you can create a hole feature.0
