Scale Issue When Exporting to Illustrator
Whenever I export a drawing sheet to Illustrator, the scale is slightly off.
For example, I have a part that's 609.1 mm. When I export as DWG or DXF, it becomes 575.537 mm. If I export as PDF, it's 608.818 mm.
Does anyone have any suggestions for how to fix this?
  • viru
    viru ✭✭✭✭
    @sam_freeman,Can you please open a support ticket and give some more details to Onshape support team they definitely help you.
    If you would like help with a document or you have encountered a bug, you opt to Share the document with Onshape support by clicking the Share with Onshape support toggle button at the bottom left of the dialog. When shared, the toggle button turns blue.
    When a document is shared with Onshape support, the Share toggle button turns blue; at any time you can unshare the document with Onshape support by clicking the toggle link again.
