Creating Threads - Boolean Operation Does Not Generate Valid Geometry
john_wolter_personal
Member Posts: 3 ✭
I have tried to create threads on a part using the technique in this Tech Tip: https://www.onshape.com/cad-blog/tech-tip-creating-a-thread
However, when I try it I'm getting an error, typically "Boolean Operation Does Not Generate Valid Geometry"
Here's an example https://cad.onshape.com/documents/77dca40eeab496b22cfbef5b/w/80f78b161cc5c6dbfa2039d4/e/b71cda6c2eeb68ec1dc8d1c0
Your profile sketch (Sketch 2) is at a slight angle (it is rotated), and as you can see it is blue, meaning it isn't fully constrained. Add a vertical constraint to the vertical (which currently isn't fully vertical) part of the triangle, and you're set.
5
5 -
Thanks, øyvind_kaurstad, I didn't notice the blue. I had a feeling it was something simple...
