ANSI fits and tolerances
daniel_mattsson_boze601
Member Posts: 1 ✭
Maybe I am missing something, but the hole wizard doesn't seem to have ANSI or ISO fits and tolerances. To me this is fundamental. I am used to working in SW which is quite mature in features, so maybe this will be in the future of OS.
1
@ daniel_mattsson_boze601 , You can find the ANSI and ISO standards for hole feature in part studio.
At this stage Onshape don't have hole wizard in drawing.Hope it will be there in the future update.
Daniel was referring to be being able to distinguish the fit information in the hole feature - or tolerance, or tolerance class . Manufacturers do not look at two holes with the same nominal size, but different tolerance as the same things. They are separate and will most likely need separate tooling and processing and inspection. We hear you @daniel_mattsson_boze601.1
