Rotation
al_lenk
Member Posts: 2 ✭
Hello All,
Is there a way to rotate your object X degrees at a time? If i press the left and right arrow key it rotates the object to much. If I hold right click down, its really hard to only rotate the object in a single acis. Is there a way I can rotate the object in a specific axis in increments of degrees?
Thank you
Thank you
@al_lenk, if you want to rotate in part studio then you have to perform transform operation as shown in below video.
If you want to rotate part in assembly studio then you have to create mate connector and give fastened relation by selecting any axis as per your requirement from origin. After that you can change rotation angle of mate connector as of your choice. kindly refer below video for more detail.
6
6 -
Thanks for the info0
