MM and Inch in the same document?
Hi,
Is it possible to have mm and inch drawing and parts in the same document? I am working on an assignment for a class and I have to draw and dimension parts with both inch and mm measurements in the same assignment.
  • dustin_allen692
    dustin_allen692 Member Posts: 3 EDU
    Yeah, I do not need mm or inch in one part. What I need is mm in one sheet and inch in another from two different parts in the same document. What I have experienced so far is that the document has a default unit. Let's say the default is inches, if I needed a part that was in millimeters in the same document so that I can have all the sheets together in the same pdf I have to type mm for all the dimensions as I create them. This is fine, but when I go and create the drawing my mm dimensions come out as inches. So my question is in the drawing can I have one sheet in inches and another in millimeters? Is this clear as mud now? ha ha
  • dustin_allen692
    Thanks, Pete, that helps a lot.
