What do the different colored lines mean when hovering over a constraint?
robert_wells594
robert_wells594 Member Posts: 7 ✭
edited September 2016 in Community Support
Total n00b here.  Trying to learn.  I get that when I hover over a constraint, the lines or points that the constraint applies to are highlighted.  But I see two different colors depending on which constraint I hover over.  For example, sometimes, the line coincident to a point is highlighted in yellow, and other times a line coincident to a point is highlighted in brownish-orange.
This really comes up because I'm trying to set the width of a sketch in this model (https://cad.onshape.com/documents/f4031af9af54844ac44310ff/w/d92db0a66ced0aafeb5a23a7/e/9aaec91f0dbbfd53b50fa714) but when I do, the curve on the right hand side of the sketch gets wonky.  I assume it's because I'm doing something wrong with constraints somewhere.
Any suggestions would be awesome.
Thanks,
Rob
  • viru
    @robert_wells594, Can you make your document public so all user can view and will provide some solution for you.
