Things not working like the examples!! ??
Sunkmail
Member Posts: 20 ✭✭✭
New to the program and having trouble getting anywhere.
1) I tried to use the 3dx app
I'm subscribed, but I don't seem to have he option to use it. the "add app" option on the bottom tabs doesn't seem to exist.
If i go to account settings, under Applications, it says:
You have not granted any applications access to your Onshape account.
If I go to the Subscriptions part of the settings, it says I am subscribed
2) On the Documents launch page, it states I have 3 private documents, but I only have one project so far, and it's public.
I did do a bunch of tutorials, but since removed the copies from my documents. Ideas?
3) Is there a way to change the color of a single face on a part? I can only get the entire art to change color.
4) How would I add a texture map (Is that the right term?) to a part?
I'm designing something to fit onto some existing brickwork and would like to have it look at least a little like brick, if possible.
Thanks!
Thanks!
@scott_mitten -
1. to add an app to a document, select the + icon in the bottom left and choose "Add application" from the menu. You'll be presented with a list of the apps that are available to you there.
2. I ran a recalculation for you as this can sometimes get out of sync, but it still reads 3 documents. Have you checked your trash? Documents in the trash count toward your limits, so be sure you empty it to remove any documents that you no longer want.
3 and 4. Changing the color of individual faces and adding texture maps to parts and surfaces are not yet available in Onshape.
Hope that helps!Abe Feldman
UX/PD/Community Support5
@scott_mitten -
