Drawing help
andrew_hicks
Member Posts: 7 PRO
In my assembly suite i have a view with the main part hidden and only the selected ancillary parts shown, is that view able to be transferred into the drawing sheet.
@andrew_hicks,Currently user are not able to select individual part/ edge in Onshape drawing so this facility is not available in Onshape. You can raise improvement request for this. In near future we hope that this facility will be provided by Onshape.
5 -
@andrew_hicks Your drawing will have all the parts shown even if you have hidden some of the parts in assembly. At this point of time we cannot hide any part in drawing. But still if you want any part not to be shown in the drawing, as a workaround you can suppress it in the assembly, so that it won't appear in drawing. But this is not a standard method.5
5 -
