start a line at an exact position
jacques_chaurette
Member Posts: 7 ✭
how do I start a line at an exact position? For example at 1 inch left horizontally from the origin.
Thanks,
Jacques
Thanks,
Jacques
@jacques_chaurette please take a look at the second part studio of this document: https://cad.onshape.com/documents/e9b7c9ec7a6be8c12ed4f510/w/fdccace106c7e82ca6c61933/e/64c3e2c9d0f395de332df304
You will need to make a private copy in order to edit sketch one. You have to dimension the line with respect to the origin. Is sounds like you need some training in getting started with cad. We have some great online resources for you to get started here: https://www.onshape.com/learn-cad-online5
You will need to make a private copy in order to edit sketch one. You have to dimension the line with respect to the origin. Is sounds like you need some training in getting started with cad. We have some great online resources for you to get started here: https://www.onshape.com/learn-cad-online5 -
OK, thanks I will do that.
