OnShape Project Reboot: Question 1: Biggest image size for a single image in a sketch?
OpenR2
Posts: 188 ✭✭✭
What is the biggest image size that I can use for a single image in a sketch?
I have hi resolution scans of blueprints that I want to trace over.
What the upper limit on file size for each image?
I would like to bring each one in at the highest resolution possible.
I'm not sure there is a hard file size limit, but I imagine you will start to see a slight performance lag the larger the files get. I just tried an 11472 X 6429 pixel (159.3 in X 89.3 in @ 72 DPI) image, which is 34.2Mb. There's about a 1sec lag when I initially try to drag it/resize it, but other than that no issue at all. Does this help?5
