Tutorial 2 - Build a Part - Question
This is referring to the video on building a part....
The front plane is selected. A centered rectangle is drawn and then the plane is moved before drawing a second rectangle.
How do you move the plane as was done in the video? I've read the keyboard shortcuts and many forum posts. But I'm missing it somehow. Thanks!
  • mahir
    I don't know which video you're referring to. What do you mean by "the plane is moved"? Depending on what you're talking about, there are several ways to "move a plane". You can create a new plane that is offset from an existing plane. You can graphically move and change the size of a plane by dragging one of its corners or sides. This doesn't actually move the plane since it's infinite, but it does move the graphical representation. Or, are you talking about dragging the depth manipulator while creating an extrude, which looks like you're moving the end plane of the feature?
