Does Onshape have an automatic constraint functionality similar to Inventor?
lukas_bridgeman
Member Posts: 2 ✭
So, let's say you've got a complex .dwg that you just want to import because you're too lazy to simplify it... in Inventor you'd just autoconstrain the whole shebang and you're off to the fully-defined races... and can delete constraints as you need later on. Anything like that in Onshape, and if not, might it conceivably be possible in featurescript?
@lukas_bridgeman, Currently automatic constraint function is not available in Onshape. You can raise improvement request for this. In near future we hope that this facility will be provided by Onshape.
6
6
