Turning a 2D cross section into a 3D drawing
ryan_lusher
Member Posts: 3 ✭
Hello
Looking for some help. I am a cable draughtsperson. I draw out cross sections of cables all day but was wondering if there is away using Onshape to convert them into a 3D drawing. There doesn't have to be twists or anything. I just need help designing it as I have never really used any 3D drawing packages before. It would be good if I could show a bit of each i.e. the copper, then the insulation, then the sheath material. Like in a layer I guess is the best way to describe it. Any help would be much appreciated.
Thanks in advance.
Thanks in advance.
You might find this tech tip to be useful: https://www.onshape.com/cad-blog/turning-your-old-2d-drawings-into-3d
Let me know if you have other questions.5
Sounds like it should be a fairly simple set of extrusions. Can you share a sample of the section views you already do? You might be able to import one as a dxf and build it fro
