How can I create a new sketch over extrudes?
Hi, I'm a newbie to onshape.
I'm learning how to use this marvelous tool!
Anyway, I'd like to create a sketch including surfaces [1], [2], [3] at once. (They all have same heights)
Unfortunately, when I select the surface [1], and create a sketch, I can't select the points on other surfaces (2), (3), (4).
For example, if I start drawing a rectangle from the point (1), I can't finish it on the point (3) because the surface [3] is not included in the current surface.
How can I solve this problem?
I'm really sorry that I cannot explain my situation more wisely with more proper words.
Thanks in advance.
