printing sketch ???
jean_didier
I'll love to be able to print some sketch to use in the shop (aka, the basement...), will not a issue when drawing will be available (right ?? We'll be able to print drawing...) but until them, any suggestion ??
In the document menu, there is an option to "Print..." which will give an image of what is currently visible on the screen. If you get your sketch looking how you want to print it, then use that and print out the resulting image.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Currently, you can right click on a sketch in the feature list and select 'export as DXF/DWG' from the dropdown. You can print this using the program of your choice.
I hope that helps.
sweet !!!! THANKS !!!!!!0
