Kinematics and kinetics simulation in Onshape
Dan_Engerer
Member Posts: 63 PRO
Hi. Coming from the Solidworks world, the motion study tool was extremely useful. Whether that was for creating simple animations, to tracking a position or acceleration of a part or point over time, to applying forces, friction, etc. to simulate a mechanism and view graphical results. What is the best and easiest way to do this using Onshape? I've been using a lot of 3rd party applications and I'm finding that it is becoming extremely complicated (and getting costly) to use so many different "Apps" whereas a program like Solidworks does it all "in house" easily.
Thanks!
Thanks!
@dan_engerer
You're not going to fine any of these capabilities in onshape today....and I bet it will be a long time before we do.
Keep in mind how long SW has been around vs onshape.
Also the cost difference between the two.-1 -
That's really disappointing! I was sold into onshape under the guise that it can do basically everything solideorks can, if not through the program itself then through apps. Sim wise 4D seems to be the only app that is even capable, and it costs a fortune, which defeats the whole purpose of going to Onshape.1
From a parametric modeling standpoint, onshape basically can do everything sw can.....in every other area it's not even close.-1
There is also now a connection to "Simscape Multibody' that would allow to import Onshape assembly with Mates into Simulink/Simscape environment.
https://appstore.onshape.com/apps/Simulation/WDQVG4FR4C3POP7HKZGTEIAWPF4VDGEB4ATH6HI=/description2
