element selection
john_mariner
Member Posts: 6 PRO
In a sketch, i need to select only arc segments that are built on construction line circles; to make an array of the segments. Click on segment, but get whole circle. How to get only the segment?
Is the arc a separate feature created on top of the circle?
If so then right click and "select other" is what you're after I believe.
Owen S.
HWM-Water Ltd1 -
@john_mariner, You can get by "select other" option as suggested by @owen_sparks, Please refer below video for more detail,
Note:- You get arc option when right click on selection of constructed circle done on above the arc only.
