Chamfer/Round failed in SM model
icatoiu_daniel
icatoiu_daniel OS Professional Posts: 4 ✭
Hi,
I tried to make a chamfer or a round on the sheet metal model and is not working.
Have you find this problem in your model?
Thank's.
  • Narayan_K
    Narayan_K Member Posts: 379 ✭✭✭
    @ icatoiu_daniel, I hope at this stage you are not able to apply chamber before applying "Finish sheet metal model".
    You can apply Chamfer after applying this option.But the chamfer which applied after
    "Finish sheet metal model" option will not reflect in flat view.
    You can raise a improvement request for this.
