Arc dimension
fma
Posts: 87 ✭✭
Hi!
How can I create an arc dimension, as in this screenshot? I found it on a public design, but can't reproduce it...
Thanks.
Thanks.
As mentioned in our help you will use the dimension tool, select each end point first, then select the arc line to dimension: https://cad.onshape.com/help/#sketch-tools-dimension.htm?Highlight=arc length1
...how did I miss that?
Thanks !0
