how can I remove the visibility of a mirrored sketch?
GFT
GFT Member Posts: 3 ✭✭
I have mirrored a sketch across my part's mid plane and used that to extrude an additional feature onto my part. The mirrored sketch stays visible. I can not figure out how to make the mirrored sketch invisible as it is getting in my way. The normal "eye" icon to hide the sketch doesnt appear next to my mirrored sketch.
  • GFT
    Ipadpro, doesn't show an 'eye'....I see there has been an update for this problem. I remade my Model without the feature mirror, so I can't check if it's resolved immediately. I will create something to test this.
  • Jake_Rosenfeld
    edited February 2017
    GFT,
    Sketch Mirroring should only be possible within the context of the sketch feature itself (not a Mirror Feature).  Does the eye not appear next to the "Sketch <X>" Feature?
    EDIT:
    One of my coworkers pointed out that you can 'Feature Mirror' a sketch.  My bad.  I get the little eye to hide the mirror (and it works as expected) on the browser, but this functionality has not been implemented yet on mobile.  What platform are you using?
  • GFT
