CIrcular Pattern on an offset plane at an angle
jan_jakub_rychlicki
Member Posts: 1 ✭
Hello,
I am designing a simple metal air blower that I want to use as a dryer for a long piece of tubing.
The tubing goes through the airblower where 8 little holes blow air at the tube.
The airblower is basically a hollow cylinder with holes drilled on an inner face which is partially chamfered conically from the
inner part of the cylinder. I managed to design the cylinder, make a shell and design 1 hole.
I'd like to use the circular pattern to extrude the rest of the holes but I think OnShape can't do this because I had to offset 1 plane and then create another plane at an angle from the one I offset to drill the whole perpendicularly.
Any ideas how to better manage this ?
https://cad.onshape.com/documents/776e97843541b609206bd097/w/10d28aaebcd151a236bdb5e8/e/21b46fefa4e45271ab14635d
1
This is what the 'Face pattern' choice in the pattern features is for
https://cad.onshape.com/documents/58b99be143894d0f7d89e561/w/b1f4547c4f91ccbc3fa7af8d/e/f9e28e0eedb30fa75df02e66
Jake Rosenfeld - Modeling Team6
