Can't make simple fillet on edge - "Failed to fillet sections" message?
josh_levine445
Member Posts: 7 ✭
Can you post a link to your document here?
@Jake_Rosenfeld Might be nice if the interaction arrow *always* appeared regardless of the initial value. Without the arrow, there is no visual way to adjust the parameter. Might also be nice to always pick a valid initial value.
Thanks again!
