Basic Assemly workflow when make small changes on parts
thomas_burchard
Member Posts: 2 ✭
Often in a assembly you want to make some small changes on some parts and to get back to the assembly ( automatically !) updated with the changed part as it is a usual practice with other 3D modeler. What is the standard procedure to achieve this workflow ? I've no clue in the moment.
Thanks fo response
Thomas
Thanks fo response
Thomas
Thomas - as it happens, there is a neat trick you can use to do this!!!
RMB over the part in the assembly that you want to edit - select 'edit in context'.
This will take you to the part studio containing the part. You will see the rest of the assembly ghosted - just ignore it.
Make the changes that you want and then hit the 'Go to Assembly' button top center of the Part Studio graphics area - you will be taken directly back to the assembly.
(Note - no 'Context' is created because you didn't reference any of the geometry from the assembly).
I hope this helps - Philip . . ..Philip Thomas - Onshape0
