how to draw thread on a plastic bottle cap?
rajesh_nair102
Member Posts: 3 ✭
I need help in designing a cap for the plastic bottle neck shown in the image. What could be the best possible method to design a cap with threads matching with the profile of the threads on bottle neck?
Depends on what your design intent is...
Product to injection mold?
To 3D print?
To render and just look bottle-like?
A couple of ways.
(1) Extrude a circle and boolean subtract the bootle
(2) Extrude a circle and sweep-remove a thread profile around a helix
(3) Revolve a cross section of the cap through 360 deg.
Owen S.
HWM-Water Ltd5 -
If you're making a cap that needs to perform correctly on that bottle finish, you should check the internet for SPI bottle finish (and closure) specs. There are several tables available that will help you design a closure that will work.
Use the helix feature to sweep a thread profile at the correct pitch etc.
Good luck!5
To 3D print?
A couple of ways.
Owen S.
HWM-Water Ltd5 -
Good luck!5
