Andreas Fehrmann
lone_rider
Member Posts: 2 ✭✭
hi, I'm a newcomer to cad, so please excuse my ignorance and lack of knowledge...still learning.
iPad app: I've drawn a simple rectangle starting at the xyz intersect and then extruded by the same dimension to create a perfect cube. So far - so good.
No matter what surface I select, I cannot get the 'Hole' tool to appear to drill through the cube. What am I missing / doing wrong?
thanks...
thanks...
Create a sketch on one of the surfaces. Place a point. Now you can use the hole feature to place a hole located on that point.0
