While I wait for 2D drawings as an output option...
Can I simulate it somehow?
I don't see a text tool. but Dimensions would be a fine start. Should I make a new sketch in each of the planes and populate it with items that span my part (unfortunately it is all surfaces imported so the sketching will not catch the points of the item... or at least not when I am driving)
andrew_troup Member, Mentor Posts: 1,584 ✭✭✭✭✭
For adding non-dimension text, your best bet is probably to orient the model as you want it, then spit it out as a png and add text in your favourite image editor .... even "Paint" works at a pinch.
To provide the png output, click on "Print" and you will be taken to a window where you can optionally (via RMB, if memory serves) Save As an image file.5 -
onshaper Member, Mentor Posts: 94 ✭✭✭
Export as a *.DXF and open it up in Solid Edge 2D. It's free and ANSI/ISO/DIN/JIS etc compliant. Awesome software!6
Engineering Consulting Partner
Professor, Engineering Technology, Palomar College, San Marcos, CA
sowelldevon@gmail.com
760 809 9046
CarlsbadCAD Carlsbad,CA
760 809 9046
I'm off to give that a go.
