Create drawing from assembly doesn't show surfaces.
scott_caskey
scott_caskey Member Posts: 56 PRO
I have some surface objects that are used in the assembly but when I create a drawing and insert views, it doesn't show the surfaces.
  • Tony_C_
    Tony_C_ Member Posts: 281 PRO
    You need to add thickness to surfaces for them to show up in the drawing.
