"Operation cannot be completed as it would modify a saved version"
Tony_C_
Member Posts: 281 PRO
I'm getting this message when I try to move parts/assemblies using "move to new sub assembly" command.
Anyone know why?
Anyone know why?
Guess I found a "fix"
I was selecting via a window and encompassing assemblies to add to the new sub-assembly.
When I manually selected each assemblies and parts in the instance tree window I was able to move what I wanted to the new sub-assembly.0
When I manually selected each assemblies and parts in the instance tree window I was able to move what I wanted to the new sub-assembly.0 -
@Tony_C_
I have the same problem, could you explain your fix? I am trying to move parts in the assembly tree but get this message.0 -
I suspect you might be trying to move a subassembly child instance and the subassembly is from a specific version of a document. You might have to open the subassembly in question in its own window and do the move operation thereBenjamin_Dellal said:@Tony_C_
Are you selecting the only the assembly and parts in the tree? You just need to manual click on the assembly and not the parts within the assembly.Benjamin_Dellal said:@Tony_C_
