How do i extrude a hole in a plate?
pierre_laplante
Member Posts: 2 ✭
Trying to extrude a hole cut in a plate and having no luck. Help is appreciated. Thanks
Hi Pierre,
The trick is to use the "extrude" feature with the "remove" option selected. Here I have created a plate with a simple rectangular extrude, then sketched a circle on one of its faces and am using extrude->remove to cut the hole in the plate:
https://cad.onshape.com/documents/1fd68aa486ce9e66c26cda71/w/e71ef8738e0880b5e8c277f7/e/f448403a380160e9e90560be
Let me know if this is not what you were asking about.
Jake Rosenfeld - Modeling Team0
