Freeze when drag selecting an area within a sketch
javier_cardona
javier_cardona Member Posts: 2 ✭
Hi,
I frequently run into this problem:
1. open a sketch
2. draw a few entities, (e.g. a polygon)
3. while the polygon tool is active, I drag and drop (erroneously thinking that the select tool is active).  When I do that, onshape becomes unresponsive.
The screenshot below shows the issue.
I can easily reproduce this.
The workaround is to reload onshape and lose all the work I did on the sketch.
  • bradley_sauln
    bradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    Please file a feedback ticket on this so we can help out. What browser are you using as well? I saw this problem for a while with FireFox and when I switched to using Chrome it worked fine for me.
    Twitter: @bradleysauln
