linear pattern
martin_streat
Member Posts: 2 ✭
I have created a linear pattern of boards on a wooden staging. i need to edit 2 boards for cutouts etc. is this possible?
Hi Martin,
Are you doing an instance pattern in an assembly or a pattern in a part studio?
If you are in a part studio you should be all set to edit those other parts.
If you are in an assembly, you will not be able to edit individual ones of those parts because they are all instances of the same part. You could try the following:
Only insert one board into the assembly
Create a new part studio in context of the assembly by right clicking the origin
Copy and translate the original board using the "transform" feature to get a new board in the position you want
Use references to the assembly (such as boolean subtractions) to make appropriate cutouts on the board
press "Insert and go to assembly" at the to insert your new board-with-cutouts
You can do this for all the boards that need to be special, and just insert instances of the base board for boards that don't need to be special. Let us know if this works!Jake Rosenfeld - Modeling Team0
