Loft and path
david_bazzelle
david_bazzelle Member Posts: 4 ✭
I'm trying to reproduce the object made in this video The Golden Ratio.  The feature just released helped out greatly, but it isn't quite working as can be seen in my version of The Golden Ratio.  Any hints would greatly be appreciated.  Thank you..
  • scott_harris
    scott_harris Moderator, Onshape Employees, csevp Posts: 66 image
    David... Bump up the number of sections (50 works great for your example). With the tight curvature at the end, you need more sections for better definition.
    /Scott
    Scott Harris / Onshape, Inc.
