line angle
Phil Mc
Phil Mc Member Posts: 2 ✭
edited April 2015 in Community Support
Dumb question but in a sketch, seeing as the rotate command isn't here yet, how do I draw a line that is say 45degrees (or whatever degrees) from vertical or constrain the angle or do a properties enquiry (look at the properties of a line to know the angle)?
  • paul_chastell
    paul_chastell Onshape Employees Posts: 133 image
    https://cad.onshape.com/documents/902001d23e584588969110bd/w/ef83e00ade964ae9b32fac61/e/eedf86c5ae6f482e9e346fce may also be of interest. I dimensioned the line to the Right plane to give it a 45 degree angle from 'vertical' without using construction geometry. I also added a driven dimension to the top plane. As you change the driving dimension the other value will update.
    Paul Chastell
    TVP, Onshape Labs
  • Phil Mc
    Thank you Jake.
