Sheet metal rules
bryan_lagrange
Member, User Group Leader Posts: 1,047 ✭✭✭✭✭
Has anyone created a Feature Script that would populate Sheet Metal data such as bend radius, K factor, Material Thickness, Material type?
If you could have a place to input the data listed above and when the Feature Script would be activated it would use this data and create a drop down list to select what sheet metal template you want to begin with.
