How do I use different radius for each bend in a sheet metal part ?
david_brodie
Member Posts: 3 ✭
I have a flange for a custom I-beam profile that needs to follow the radius cut into the web.
Nevermind, lol, use the sheet metal table in the flat view0
Hi David!
Have you checked out the simultaneous sheet metal table? If not click this button on the right side of your part studio:
Once you have the table open, you can double click on the "radius" of any bend to edit just that bend radius to the radius you desire. You can even drive the bend radius with a variable!
https://www.onshape.com/videos/sheet-metal
https://cad.onshape.com/help/Content/variable.htm
Jake Rosenfeld - Modeling Team5
I would make each bend a new flange and you are able to adjust radius at that point.0
Hi David!
