Error with "Variables" in sketch
mitchel_palmer
Member Posts: 20 ✭✭
Hi there,
i cant seem to get my variable to work in this sketch. can anyone help?
*i have just saved the file with a numeric value
https://cad.onshape.com/documents/dfd463c329baadcb71cf923a/w/7641a894ea47965649c0d62c/e/a4d1fb8632ab60571edbb2a6
note i have no problems with using variables in the top plane - see the last sketch at the bottom.
any ideas why i cant use the variable here as indicate?
thanks in advance
mitch
thanks in advance
mitch
Not yet, but it's a highly requested feature so I'm confident OnS will address this soon.mitchel_palmer said:oh i see, so there is no global variable manager like Solidworks?
There is an IR you can vote on here if you'd like it to be prioritized:-
https://forum.onshape.com/discussion/comment/29703#Comment_29703
Cheers, Owen S.
HWM-Water Ltd5
variable defenition should be done before the feature you want to use variable in, it is just like with any another feature
1 -
oh i see, so there is no global variable manager like Solidworks?0
yes, thought if you define all the variable on the top of the feature tree they all will be avaliable in any feature after that
Cheers, Owen S.
HWM-Water Ltd5
