Extrude cylinder through xyz path
austin_boles
Member Posts: 2 ✭
Does onshape have the capability to extrude a cylinder through an xyz path from a text file?
Yes, but I think you have to use FeatureScript -- it can read csv files you upload.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Here is the link to a custom feature that will read a CSV file (x,y,z) and (in this incantation) pass a spline through those points
https://cad.onshape.com/documents/f8191d0fd7fe9a488e8dcd15/w/29be675d29fa9f017b6fed6e/e/ede068561c3e9bc56af1fd3a
Philip Thomas - Onshape0
