Boolean Union
gideon_grossman
Member Posts: 2 ✭
I am trying to design a mold for a silicone wristband. I have an insert part that enters the center of the silicone to leave a cavity. And there is an outer mold that forms the outer shape of the band. I would like to connect these two mold parts. I am trying to do so with the boolean union tool. The part for which I am designing the mold seems to be interfering. Why? How can I connect the two mold parts successfully? Thank you very much for your help.
https://cad.onshape.com/documents/e356ddd9537696c52f673ca6/w/e399254c79a3dc148b8bcc9d/e/64f7844bddea06a4faee7476
Boolean unions pretty much only fail if there's zero-thickness geometry created between the two parts, which is the case here:
Arul Suresh
PhD, Mechanical Engineering, Stanford University2
