Scaling entire model or assembly
drew_pate
drew_pate Member Posts: 1 ✭
I really love Onshape, it has met all my expectations. Unfortunately, I designed my whole model and discovered that it was too small. How would I scale the entire model without going in and editing each and every dimension?
  • emagdalenaC2i
    edited August 2017
    You can scale with the transform feature, but usually this option is only used to scale all the part uniformly (Generally to increase a part to create their mold, because the injected parts are compressed upon cooling after leaving the mold)
    If you want to scale a complete assembly, yo can:
    1. create a new context in the assembly
    2. create a copy of all the parts with transform and the option copy in place
    3. and then scale all the parts
    Un saludo,
  • emagdalenaC2i
    Usually is better to use the move face feature, like you can see here
    Un saludo,
